- Mute
- Permalink
- Report
Hi everyone,
I'm trying to create a tool to visually highlight certain portions of a beam. To acheive this, I created a simple parametric "cube" in the W Flange beam family where the size and position (with respect to the beam) of the cube are all controlled with shared parameters.
All of the parameters work great when testing them within the family, but when loaded into the project, the parameter that is supposed to move the cube up and down relative to the bottom of the beam (parameter is called 'From Bottom') is shifting the beam's position instead of the cube's.
I've seen a similar issue on another post, but still haven't been able to figure this out. What is confusing to me is that a similar parameter ('From Edge'), which controls the position of the cube relative to the beam's edge works fine (it doesn't move the beam's position left and right).
Any and all advice and help is greatly appreciated. Attached is the W Flange with Cube family file, along with a sample project as illustrated below.
Thank you in advance for your help.
-Brendan
