Shared parameter in title block
i am trying to give get a shared parameter on a dimension in a title block. I figured out that it can be done with a label, but obviously not with dimensions 😞
I've a revison scedule, so when it grows, my title blocks above it has to move with it, so now i am doing it manualy..
any ideas are welcome!!
LisaDrago
This is one of those things I have never been able to figure out - so every company I have worked with is to just leave enough room for the schedule to fill out - usually leave enough for 10 revisions, although we have never hit is.
Not the best answer you were looking for.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Mirko.Jurcevic
Check this:
http://forums.autodesk.com/t5/revit-architecture/shared-parameter-in-title-block/td-p/5560576
And this:
http://forums.autodesk.com/t5/revit-architecture/sheet-size-in-title-block/td-p/5569686
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
