- Mute
- Permalink
- Report
I was creating a Host Thickness (HT) Shared Parameter to constrain to a loose RefPlane. The reason being is that I would like to schedule that dimension on a set of joined walls. The idea was to make it an instance so that we would align that RefPlane to the face of the Wall it needs reporting to.
We have 2 windows in the project (file attached). One of them allows for the HT to be picked and moved, i.e., it shows the grips. For the other one, however, it doesn't and it is greyed out on the Instance Properties.
I tried to remove and readd the Shared Parameter to no avail.
Can you suggest something?
Many thanks.
J
Assistant BIM/CAD Manager
Manchester, UK
Manchester, UK
