First of all, apologies for posting so many queries, trouble is I'm working in isolation most of the time and can't really bounce ideas around.
This may be an obvious query - I've set up a door assembly family, and nested individual door leafs. I've managed to share the parameters and can control them from the host family - and in the main this works fine - at least until I place more complex options in the mix.
Do shared instance parameters that apply to one door panel need to apply to all door options ?
When I limit the shared (linked) instance parameters that are common to all door panels, it works fine. But if there is an instance that applies to one door leaf only, but not the others, it spits out the error:
"Failed to apply family parameters."
In other works, should I limit the shared instance parameters to only the common elements (materials, overall door width, height, thickness etc.) and have the more specific parameters limited to 'Types' ?
I've attached the door assembly file in case some kind soul has a few minutes to look at what I'm trying to achieve. I may be using far too many shared parameters.
Many thanks
Martin
