Revit 2013, Restore Render Function
jsworks
jsworks
I have lost my Render function (tab is grayed-out). Can anyone suggest a method to restore the function without having to remove and reinstall the program?
Jim
LisaDrago
Hello and Welcome to the Discussion!
Can you post an image of the screen? I am interested to see what view you are in...
You can reset the user interface by removing or renaming the UIState.dat file.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
jsworks
Hello Lisa,
See the file attachment for a screen shot. In the View tab of Revit, in graphics category, there are 3 render options. The first "Render" option has become disabled. Your suggestion of resetting the User Interface might work, but since my technical knowledge is limited, I will need step-by-step instructions.
Thanks for your reply,
Jim
jsworks
This problem is resolved. Apparently the Render function is automatically grayed out if you're not in the camera view.
