- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
New to Revit 2022 is including Shared Parameters in key schedules but I'm bumping into an error "Parameter cannot be set by key schedule" for nested, shared family.
What's working: The basic HM doors/frames, the door type is set by a shared integer parameter (yay 2022!) with a key schedule assigning a door schedule (F, G, etc) linked to numbers. In the family, a nested door panel family type is set with an if statement to the number to show, flush, half lite, etc. User picks the door based on the Key Name and everything updates. So far, looks good.
What doesn't work: Storefront needs to be window family to be correctly tagged and controlled graphically. We can't use Revit curtainwall, too many issues. For doors in storefront, we have nested, shared door family with identifical features/parameters as the above doors. However, in trying to control the shared integer parameter by key schedule, Revit gives the above error and will not set the number per the key schedule.
The only reference to this I can find online is the Revit 2022 Enhancements lists notes: Added an icon and tooltip in element properties for all parameters included in an assigned key schedule, which indicates the status: 'Parameter set by key schedule' or 'Parameter cannot be set by key schedule'.
Any help on getting the key schedule working for the nested family is much appreciated!
Follow-up: Could be a nested family conflict, not a key schedule conflict.
Further investigation may be that I understand nested families less than I thought - I'm finding that instance-based parameters in the nested family are grayed out when they're made in the nested family. Project made parameters for that category operate just fine, but the moment I put that same parameter into the nested family do some operation, Revit grays them out.
