- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Two project files, and a shared coordinates file. The project files have been linked into the Shared Coordinates file, positioned on the site plan, and coordinates published. In each project file, the positions have been acquired from the Shared Coordinates file. So far so good...
Project 1, True north is correct in the file. This project was set up a while ago, and it must have been done in the beginning before the Shared Coordinates were made.
Project 2, True north is incorrect, and just the same as Project North.
- Should I set True North in the Shared Coordinates file? Or do it individually in each of the files (Project 1 already has this)?
- Will True North changing in the Shared Coordinates file affect each project?
(A separate Shared Coordinates file with nothing in it has proved to be the most understandable way to manage locations. But I am still green at this, as it is a simple, but yet complicated thing...)
