Share Model via Bridge in ACC
shahin_kiyomarsi
shahin_kiyomarsi
How come when I bridge my model from my ACC to another ACC, its not a workshared cloud model anymore?
Tom_Kunsman
The Bridge function of ACC is to share INFORMATION, and not live models - you can share "as built" (static) revit models - https://help.autodesk.com/view/BUILD/ENU/?guid=About_Bridge#key-functionalities-of-bridge
shahin_kiyomarsi
apparently we can only do this on revit 2023 and beyond. The reason why it didnt work its because im doing it on 2022. as per customer support from Autodesk.
Tom_Kunsman
that is correct, the Bridge function is only for Revit 2023 and newer. You can always upgrade your project on the Cloud, assuming any consultants are also working in 2023
