Shadow Parameter Globally Changed
tdaltd
tdaltd
Other than using view templates, is there a way to change shadow density for all views in a project? It seems that my current default is 50% and I would like to make every shadow in the project 25%
I really should set this up properly in my starter template, but for now, changing the shadow parameter globally would be a big time saver.
Tom
tdaltd
Thanks Bart
This is how I have been doing this but it is still view specific, which it should be!!!
However, I currently have over 4o views set up, including plans, elevations, sections and perspectives, in a number of different scales, etc. so it is painfully time consuming to do this for every view and if I set up templates for each type of view I would need to establish at least 12 unique view templates.
Is there a way to move that shadow slider for every view in the project, just one time and have every view adjusted?
T
ralphdenhaan
What version of Revit do you use? And what is your experience with Dynamo?
You can create a script where you collect all your views and create a list. Then put the list into this Python script:
- Change the value of 50 to 25, in your case.
import clr
clr.AddReference('RevitServices')
# Import DocumentManager
from RevitServices.Persistence import DocumentManager
from RevitServices.Transactions import TransactionManager
# The inputs to this node will be stored as a list in the IN variables.
doc = DocumentManager.Instance.CurrentDBDocument
views = IN[0]
#List with Views
if not isinstance(views, list):
	views = UnwrapElement([views])
else:
	views = UnwrapElement(views)
TransactionManager.Instance.EnsureInTransaction(doc)
#Shadow Intensity
for view in views:
	view.ShadowIntensity = 50
TransactionManager.Instance.TransactionTaskDone()
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
