Hello all!
Is there any way to set up an adjustable wrap distance in the labels? (Revit 2018)
Thank you!
Hello all!
Thank you!
Can you upload an screenshot to clarify what are you referring to?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
...oops. Time for new glasses. he, he.
...you can make the box parametric with Type Parameters controlling size and then duplicate and create different Family Types/Sizes as needed on the go in the Project
...or, am I still not seeing correctly? 😉
@JML_Mela wrote:
Hello all!
Thank you!
No.
If you create multi-line text labels, you can manually set text line breaks by editing the content.
