copy beams from another project
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
adel.alyasin
291 Aufrufe, 2 Antworten
Hi
so I am working on a project where the structure is modeled buy another company
they have made some issues and we do not want to wait till they fix them so we decided to copy there work and work further on our model but the problem is that they have beams modeled on levels we do not have so I made the same level on the same high and also the same name (not that the name will make a difference)  so now when i copy there beams and paste them (aligned to selected level ) the reference level is not the level I have selected in first place  the position of the beam is also not right (in the 3 dimensions )
note: if we link there model (by shared coordinates) the models are perfectly aligned
thanks :leicht_lächelndes_Gesicht:
2 ANTWORTEN 2
Nachricht 2 von 3
rxi.gg
als Antwort auf: adel.alyasin
Have you tried to Bind Link?
https://help.autodesk.com/view/RVT/2020/ENU/?guid=GUID-3AC5B298-828D-498A-BECB-92AEA28E5A2F
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
Nachricht 3 von 3
adel.alyasin
als Antwort auf: rxi.gg
