Set up Wall families to allow individual layers to be independent
justin
justin
My design team works closely with a pre-fabrication team who works in CADwork. They take our RVT files and create more detailed struc'l models that are used to communicate with our CNC machines and create more accurate takeoffs.
They have requested that we set up the wall families in a way that would allow them to individually select wall layers (Struc'l Core, plywood, siding, drywall, etc.) and separate/remove/hide them in CADwork.
Is there a setting in Revit 2019 that would allow them to manipulate walls that way after transferring to CADwork?
Thank you!
Create Parts from Walls.  You can have both.
