Set up vertical distance in normal text.
Darwin33
Darwin33
I have  a project where the different elements are described with annotation families. I also have some elements (very few) that are described with text. The problem is that all elements described like text have a different vertical separation than the ones described with an annotation. Is there a way that I can adjust the vertical separation between lines in a normal text. It seems to be a basic feature.
No. You would need to place individual lines of text.
That's been a wish-list item since Moses wore shorts.  I'm sure the Ideas Forum is full of requests for this "feature".  Jump on board one of those - but don't hold you breath.
