SET HEIGHT FOR RAILING?
VicBerg
VicBerg
Hi!
Does someone know a way of how to change the hight of a railing?
Kind regards, Victor
Edit type.
VicBerg
In edit mode and then edit - Rail Structure (Non-Continuous) i find the column-HIGHT bUt it only change where my raIling starts. The type in the column-PROFILE seam to decide the hight of the railing but the alternatives are preset.
Kimtaurus
Can you further explain what you're trying to achieve?
Editing the height of either the Toprail or the height in th Rail Structure will change the height of a railing.
Do you want to change the heigth of the entire railing or the height of one of it's components (railing, baluster, post)? Or the height where the railing is placed?
_____________________________________________________________________________
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
VicBerg
I manage to change the hight by changing one of the Profiles families. Maybe thats whats ment by changing hight of Rail Structure.
Kimtaurus
I'm still not following your process. Did you change the dimensions of the profile?
"Maybe that's what's meant by changing height of Rail Structure."
Why are you saying this? You were the one asking us the question in the first place.
Viveka_CD
Hi @VicBerg
Please see the article HERE to Change the height, offset, profile, material, and the number of rails within a railing type.
See the video below for editing railings
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you,
