set accuracy and snapping
Shay.Gaghe
Shay.Gaghe
Hi
I have inserted a CAD as a reference, the CAD is not accurate (i.e instead of 580 it measure 579.78) . I want my Revit walls to be accurate and respect intervals of 5 units.
How can it be done?
S
Using Autocad 2018, Autocad Architecture.
Please accept as solution if i solved your problem
You will need a combination of the list of Snap Increments only including the necessary value, and manually adjusting temporary/permanent dimensions after elements are laid.
