SEPARATE TAG FOR WINDOW CASING INSIDE A WINDOW FAMILY
2 REPLIES 2
design01RHDW2
262 Views, 2 Replies
Hi! I wanted to know if it is possible to tag the window casing profile that i did (via sweep) inside my window family? I know that naturally we can tag the window itself, but I want to tag separately the window casing sweep I did so I can put it into my finishes schedule as a separate "trim" element. Hope someone could help me with this. Thanks!
P.S. The casing is just an in-place sweep within the family and not nested.
2 REPLIES 2
in reply to: design01RHDW2
If you create the casing as a shared family and nest it inside the window family then you can tag and schedule them separately in the project.
Tried this and it work! Thank you so much.
