How to show selective demolished items (i.e., Walls, Openings, Mat'ls, etc.) on Floor plans & Elevations?
Solved by barthbradley. Go to Solution.
You mean show via the Phase Filter (e.g. "Show Demo + New" )?
@tstewart wrote:
Yes, how to show proposed demolition items in Phase filter?
How? Like what line weight and pattern to use to indicate demo'd elements? What wrong with the pre-set, OOTB Phase Filters? They're all modifiable through Manage Tab: Phases.
...I notice that you initially specified "selected" demolished elements. Are you wanting to show "selected" demolished elements differently from other demolished elements? Look to Graphic Overrides by Element or Filter for doing this.
@tstewart wrote:
you able and will you tell me how to set-up phases (i.e., Existing, Demolition, Construction, etc.)?
I can Link you to some information to read.
Start with these:
Understanding Phase Filters and Graphic Overrides | Revit Products 2021 | Autodesk Knowledge Network
Project Phasing | Revit Products 2019 | Autodesk Knowledge Network
6 Tips To Master Revit Phases — REVIT PURE
...there's also quite a few video tutorials in close proximity to you -- just a Google keyword search away.
Start with these:
You're welcome. 😊
