Selectable but invisible element
L.Gomez.JSS
L.Gomez.JSS
I have a problem where I have some elements that when I rotate or change my section box size in the 3D view, it makes the element invisible (first image below) but I am still able to select them (second image below).
This is not a visibility/graphics, filter, workset issue, it might be a bug or something but this hasn't happened before to me. It is a small project so I don't think is an issue with my computer neither as is powerful and capable of handling heavier projects than this one.
Would you have any advice on how to solve this?
Mike.FORM
Duplicate the view where the item is visible, add a section box and see if you can make the item disappear again. If not then, delete the view that is not working and keep only the ones that do.
L.Gomez.JSS
Hi , thanks for your reply but both images are from the same view. In one view, I have the element selected but in the other one not. Just to show that is not visible but I still can select it.
-Pin it and disable Select Pinned Elements.
-Hide it in the View
BTW: I've seen this "behavior" many times before. I wouldn't call it a "bug".  If you want to post the file, we can test it on our end to confirm.
