color problem
color problem
ismailnabil00
Message 1 of 8
color problem
ismailnabil00
when i view the revit model through Autodesk online viewer , the color in autodesk viewer it is dark not same as in revit  model as per below photos.
Replies (7)
Message 2 of 8
ismailnabil00
Any one have a solution ?
Message 3 of 8
View Phase Filter?
Show Complete?
Message 4 of 8
How is the Revit model shown in Realistic?
Message 5 of 8
constantin.stroescu
Autodesk Viewer is not Revit so the 3d View can be be somehow different from Revit display.
I suggest you to place the 3d Views on Sheets and : Collaborate>  Publish Settings ,then, save the file , before uploading it into Autodesk Viewer. Then you will be able to see the Sheets(including notes and dimensions) exactly as in Revit.
Constantin Stroescu
Message 6 of 8
ismailnabil00
Yes it is complete.
Message 7 of 8
ismailnabil00
it is the same in all visual style.
as you se the mechanical model is colored , the problem only with arch. model.
Message 8 of 8
vitorbortoncello
Show Complete
A resposta te ajudou? Não esqueça de curtir e aceitar como solução!
Vitor Bortoncello | Arquiteto | BIM Manager
dAutodesk Certified Professional
