Select all views with view template?
javirod800
javirod800
Hi everyone,
My intention is to quickly select all views in my project that have a certain view template applied, because I need to change the view template for those views. I was hoping this would be possible by creating a View List and formatting by view template, but I was disappointed to learn I can't actually select any views from this list in the same way you can usually select elements from a schedule. I have to resort to finding the views in the project browser and selecting them manually, which is time-consuming as the project is very large.
Am I missing something? Does anyone know any way to easily select a group of views with common parameters?
RDAOU
@javirod800
You can try create a Project browser Filter by View Template. Not sure if that makes things easier if you filter them out first then select them in one go
javirod800
That's it! I had no idea this feature even existed. Thanks a million
RSomppi
Alternatively, you could go to Manage View Templates and delete it. Revit will ask you if you want to replace it with a different view template or just remove the template from the views.
