select all keyboard shortcut
Message 1 of 9
hello guys
i'd like to know if there is a shortcut for  [select all ]  in revit or not ?
thnx in advance
Replies (8)
Message 2 of 9
ennujozlagam
@Anonymous hello, you can try this select object > right click > select all intances > visible in view. thanks
Message 3 of 9
is there is a keyboard short cut
i'm searching for a shortcut ,,,, to select all the categories ,,,, that is visible in view or not visible ,,,, all in the file  ,,,,, so i'll select [in entire project ] ,,,, not in visible view only
Message 4 of 9
ennujozlagam
@Anonymous you can try user interface > keyboard shortcuts. thanks
Message 5 of 9
ennujozlagam
Hello, you can try this, select objects > go to sunglass icon > select category. Thanks
Message 6 of 9
diegus68
I suppose he refers to "Select All" like in Autocad. Mayby a "Ctrl + A"
Message 7 of 9
ivancruz.M_BIM
Me too! I need to know that !
Message 8 of 9
pdent1
Bumping this thread. So the answer is no, it can't be done?
Message 9 of 9
CADiva
@pdent1, I don't believe there is one OOTB, but you can edit the Keyboard Shortcuts to create one.
The dialog can be found on the View tab under the User Interface dropdown.  Find the "Select All" command and add whatever key combination you want to use (mine are "SA" for Select All in Project and "SS" for Select All in View").
Here's more information on adding Keyboard Shortcuts. It's for 2019, but that dialog hasn't changed, so it's still applicable.
