Tags are View-Specific Elements. What would be the game plan if you selected a instance of an element PLUS every one of it's View Tags?
I need to copy them into another level, anyway the mark will change, but the rest of the info stays the same.
- make them a group and Revit will create the model elements as model group and the tags as a separate but associated detail group
- paste the mode group to another view, select it and revit gives you the option to attach the associated detail group to it
or just paste the tags aligned to other views
Tag all in View not quick enough?
If there was an option to copy elements with their tags, tags would have been pasted in the exact location as they were located in the origin. that's why i was looking for it. 🙂
Revit doesn't allow you to select a tag by selecting the element first. (I wish it would.) Therefore doing it with multiple entities is a non-starter.
Select everything in view, click filter on top to filter these instances and tags, hide elements in view (HI), possibly deselect from the subset what not to copy, copy-paste aligned to selected views... ? ...that might do the trick.
