Select All In Room
Select All In Room
CodydNYY24
Select All In Room
CodydNYY24
Often times I have to select a large amount of items in a room. I would love to be able to select all in room as apposed to windowing over the room and then filtering out what I don't need.
Yien_Chao
hello
there is a workaround : since each item is a geometry, get the center point of each element. then pass the method ispointinroom().
https://www.revitapidocs.com/2022/96e29ddf-d6dc-0c40-b036-035c5001b996.htm
hope it help
TripleM-Dev.net
If you're going the API way, create a solid from the Room Mass and use ElementIntersectsSolidFilter to select all elements selectable in the room.
Would need further inspection if only elements completely inside the room are needed.
Maybe something for the API forum.
