Sectional drawings from a family
Hi there,
I would like to know how I can make a family drawing of a window and then use it in the future with customized measurements.
After I have made the family and entered a specific size for the window, I want it to make a sectional drawing so I can see the element from the respective angels and also in 3D view.
I would like the fini result to be like this (i know how to make it in inventor):
Corsten.Au
Hi
i would suggest , take any window, edit the family and study the graphics and details.
Visibiliy: plan, view ( coarse, fine etc )
visibily : cut line, projection lines, material etc
as long as you figure out those parameters, you can achieve what you are looking for..
best luck
Corsten
Building Designer
Load the family in the project normally and create Assembly from one instance of the family. Then you an create Assembly views and sheet similar to what you show.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
