Section view detail Line not snapping exactly to intersection
nick.seman
Message 1 of 27
nick.seman
Hello:
When drawing detail lines in a section view the line does not snap properly to the end/intersection of the object (see attached image). In all cases it is drawn slightly upwards (3/32" or so) from the selected end/intersection.  I do get the snap box - but it is located slightly above the object as well.  The object is a generic model.
Any ideas?
Thanks;
Nick
Replies (26)
Message 2 of 27
Turn Off Far Clip Offset.
Message 3 of 27
nick.seman
I have it set to the smallest value it will accept - is there a way to turn it off all together ?
Thanks for your help.
Nick
Message 4 of 27
nick.seman
Turned that off, but the result is still the same (shifted upwards) when drawing a new detail line.
I checked and model lines are also shifted.
Nick
Message 5 of 27
Are you using your TAB key?
...to clarify: TAB-Selection is what I mean.
Message 6 of 27
nick.seman
Yes - I am definitely selecting the end point.
I just created a sample model - a wedge shape.  I placed a section approximately 1/3 from the end.  When viewing in  section with the clipping plane set to no clip try to pick the corner/intersection where the object passes the section plane (arrow in attached image) - cannot be done that I can tell.  The snap goes to the closest end of the edge.  See images.
I have tried every imaginable setting within the Extents options.
I have included the wedge.rvt model - hopefully I am missing something.
Nick
Message 7 of 27
See attached for a workaround.
Message 8 of 27
nick.seman
Adding the ref plane might work for me - I will give it a try.
Thanks;
Nick
Message 9 of 27
Thanks;
Nick
Add it on a plan view, where you can snap to the intersection of the section line and the element.
Message 10 of 27
I can snap a Detail Line to edges just fine. No mysterious offset happening on my end.  Either I don't get what you are describing - or I do get what you are describing, and my Revit is better than your guy's Revit.  😉
Message 11 of 27
@barthbradley wrote:
I can snap a Detail Line to edges just fine. No mysterious offset happening on my end.  Either I don't get what you are describing - or I do get what you are describing, and my Revit is better than your guy's Revit😉
Let's stick with the 1st scenario.
Message 12 of 27
@nick.seman: help me out here. What is this element?  It's no Generic Model I've ever seen. Revit doesn't even list it in the Project Browser.  You got me scratching my head.
Message 13 of 27
Alright, I give up. What am I missing, Mr. Brainiac?
Message 14 of 27
The question.  You just need to read and understand the question.
Message 15 of 27
nick.seman
The object was created in Inventor and exported using the relatively new Export to RVT command.  This creates a Revit drawing with the generic object inside of it.
This is also causing me an issue - I need to add material properties to it but since it does not appear in the Project Browser I am unable to export it to a RFA, add the material info, and reimport it.  On the other hand if I change the Inventor Model I can simply "update" the Revit model and all holds together pretty good.
Nick
Message 16 of 27
Actually, you read it:
Message 17 of 27
Nick
Message 18 of 27
I was giving you a benefit of the doubt and hoping you would go back to read the question.  Alas...
Message 19 of 27
nick.seman
Is this just a "paint" or are the material properties (wood . . .) actually accessible in the Type Properties ?
Message 20 of 27
