I had a parent section view split into dependent sectors. When I moved/set the left and right extents, the callouts did not move to align with them. In the image below, the view is a floor plan that will be sectioned out using dependent views later on. I have one of several overlapping callouts highlighted (left), and the extends for it can be seen as the arrows (right). Since the callouts run so long, they all will show on the dependent views for the floor plan and overlap each other. Each floor has a set of 24 sections at a minimum, and the sections dip above and below the levels making the views for level 2 show in levels 1 and 3, and those levels sections show on level 2.
I made a new view with the same template, but the callouts still showed in the same spot (not aligned).
Using copy (CRTL+C) in the new view produces a callout that is also not aligned to its extent.
I am running Revit 2019 for this job and cannot use anything newer than that also.
