Is there a way to export a plan view including the imported NWD file to DWG? When I export the plan view to DWG the imported NWD is not included
Gelöst! Gehe zur Lösung
Gelöst von SteveKStafford. Gehe zur Lösung
Sorry, not supported - see Autodesk Article
They recommend importing the NWD used for the coordination model directly to the exported AutoCAD file instead.
Steve Stafford
Print as PDF and then have AutoCAD convert PDF to DWG.
