Message 1 of 23
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am adding a wall section from a floor plan view. The floor plan view is placed on sheet A201. When I place the section on that view my referencing sheet is not A201, but A211. A211 is a different view copied from A201. It seems to be related to the place where I put the section as well. Here is an image where I placed two sections, on this view which is on sheet A201. The lower section is referencing correctly the upper one is not.
Is there a way I can change the referencing sheet to be correct? It seems to be greyed out in the properties of the view. Thank you in advance.
Regards Peter.
