Section on a floorplan isnt visible
adnan_omerhodzic
Message 1 of 12
adnan_omerhodzic
I have multiple sections that are not visible on floorplans on a worshared model in the cloud.
I checked every possible visibility option (worksets, filters, visibility settings, phases etc.).
I opened the model on another laptop and the sections on the floorplans are visible.
The issue is that the sections are only visible on that 1 particular laptop. Model was synced multiple times, published etc.
i think it should be a bug but wondering if there is a fix for it.
Replies (11)
Message 2 of 12
Simon_Weel
Maybe update the graphics driver?
Message 3 of 12
ralphdenhaan
Have you checked this option too?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
Message 4 of 12
adnan_omerhodzic
Thanks, ill try to update all hardware and software and see what happens. Fingers crossed
Message 5 of 12
adnan_omerhodzic
yes i tried that and all the possible visibility options there are....i excluded all posilibities that it has somthing to do with the model file itslef. The same file is showing those sections on some laptops and on some they are missing on the floorplan only (not displayed).
if i find the solution to this weird issue ill post the fix in here
Message 6 of 12
Clear worksharing cache.
Message 7 of 12
Alfredo_Medina
The plane of a section must intersect the view range of the floor plan. Go to an elevation view where you can see the section line, and make sure the section's range intersects the floor plan's view range.
Message 8 of 12
SteveKStafford
If the project is hosted on BIM360 then make sure the project is set up to publish or not. If it is configured to publish then you'll have to publish the project before you'll see the changes on other computers.
Steve Stafford
Message 9 of 12
adnan_omerhodzic
I tried that, even tried singing in to another PC where i can see the sections, copied the cache from there to my computer manually and still nothing. Its a mistery still
Message 10 of 12
adnan_omerhodzic
Thanks for your answer, i did set up the Worksharing correctly, everything works except that i cant see those sections just on my computer. File is published and synced countless times.
Message 11 of 12
adnan_omerhodzic
Thank you for your answer, its not the view range since i can see the same sections on another computer, same file, same settings, except that i cant see the sections on my PC
Message 12 of 12
SteveKStafford
Clear your collaboration cache so Revit must download all resources again as Toan suggested earlier. Also clean out your Revit.ini file for recent worksets and files list.
Steve Stafford
