Section levels not visible
jinergoh721
jinergoh721
Hi all,
The Visbility Graphics >ANNO.>LEVELS is turned on, I've also tried  REVEALING HIDDEN ELEMENTS, but the levels still can't show up in one of the sections anyway.
Can you help me with this?
TQ
Jiner.
rxi.gg
Make sure the section cut the levels. See their extension in 3D and look if they are in the zone where you make the section
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
jinergoh721
Hey yup I couldnt understand, I manually fixed it with annotated lines.
TQ
Jiner
rxi.gg
Select the levels in 3d and edit the width and long
