Section Head in Families
PhilvK
Advisor Advisor
PhilvK
When I cut a section in some families, only a line appears at the section cut location – no head or tail. What setting should I check please?
L.Maas
Maybe you purged some things?
Like most of the things in Revit sections are consisting of different families
Louis
Please mention Revit version, especially when uploading Revit files.
PhilvK
You are probably right- I don't see all the components you show in your image. I'll see if I can copy or transfer them back in. Thank you!
PhilvK
I had to look this issue up again and found this post from 6 years ago. Thanks again!
