- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have used callouts to create individual views for each span of a multi-span bridge. I am taking section cuts through each of these spans to look at the parapet walls and fencing. I am placing the section in the callout view and each of the section cuts extends slightly beyond the end of each span so that I can get the view of the entire parapet. The section views are showing the elements that are in the adjacent spans even though they are clipped and not visible in the callout view. Additionally the section markers are showing up in the other callout views where I do not want them to be visible. Is there any way to get the section cut to show only what is visible in the callouts plan view and is there a way to prevent the section markers from being visible in other views without having to use hide them every time?
For reference my workflow is to use the callout feature to create a new view with just the one span. Then to place section cuts in the callout view. These are then annotated and placed on a sheet.
