Section Box does not display
Message 1 of 39
Am learing Revit 2013.  While playing with sample projects, I enter 3D view and check Section Box in view properties.  Section Box does not display.  What am I not doing?
Accepted solutions (4)
Replies (38)
Message 21 of 39
AlexDT
I can't make a screenshot at the moment, but see the reply above my reply where I mention the three boxes. It's a screenshot with a black viewport in Revit. In the middle of it you see three boxes, a yellow icon. Usually that icon is blue (with a White background). This icon will only be visible when worksets are enabled btw.
Message 22 of 39
Radish_G
Hi AlexDT,
Did you mean the crop view box? Is this the three boxes?
Regards
Radish G
Message 23 of 39
AlexDT
I've attached a schreenshot for you.
Message 24 of 39
Radish_G
Hi AlexDT,
I got it,
Currently I am out of that project, so i don;t have that project file to check. Anyway I think it will work.
By the way, what do we call that icon (3 cube), and what is the function of that option?
Thanks in advance.
Radish G
Regards
Radish G
Message 25 of 39
AlexDT
I dont know what the name would be, but it is a toggle to make elements editable. It has got to do with worksets.
When you have a central file, and are working with other people on the same project at the same time, Revit wants to make sure an element is not being editted by two people at the same time. By default elements are not assigned to anybody and thus display this toggle (to make editable).
I rarely have to use this toggle and it seems like when the element isn't claimed borrowed by another user, Revit will automatically assign the element to me. (this article is explaining this specifically: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...)
For more information about worksets please look at: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
Message 26 of 39
Radish_G
Hi, @AlexDT,
Great, info..,
I will work around it, Thanks a lot for your time & support.
Regards
Radish G
Message 27 of 39
GeckoGroen
I found another place where the Section Box can be set on/off.
That's with the properties of the opened window (don't select anything), under Extents Section Box can be set on/off.
Maybe this will help.
Grt, Erick
Message 28 of 39
This is what I was looking for. Thanks for posting!
Message 29 of 39
mmontes016
Press Reveal Hidden Elements , the tool box is hidden
Message 30 of 39
fraidyS5X9P
Observer
Observer
Thank you!!!!! Super cool!!!!! Not sure how and when i hid it but it was hidden!!
Message 31 of 39
mmontes016
glad to help!
Message 32 of 39
Thank you very much Sir. So many ways for a simple task.
Message 33 of 39
jacobusJBFYP
This was it for me. Thank you very much.
Message 34 of 39
pa1nj
Community Visitor
Community Visitor
Thanks man, Very helpful
Message 35 of 39
whittakerc
Community Visitor
Community Visitor
That worked fantastic 🙂
Message 36 of 39
SUSANDAILYASSOCIATES
In the sample file that comes installed with Revit, they hide the Section Box (rac_basic_sample_project.rvt). I finally figured out how to show it with the Reveal Hidden Elements. But I can't seem to make it unhide. Any solutions?
Message 37 of 39
jamalipari7
Community Visitor
Community Visitor
it was wonderful.thanks
Message 38 of 39
zeynab_keshavarz
Community Visitor
Community Visitor
Step 1: Reveal Hidden Elements
  1. Open the 3D view where you expect to see the section box.
  2. Click on "Reveal Hidden Elements" (represented by a lightbulb icon). This will show all hidden elements in your view, including the section box.
Step 2: Locate the Section Box
  1. After clicking "Reveal Hidden Elements," the section box should become visible in the view.
  2. Right-click on the section box.
Step 3: Override Graphics in View
  1. From the context menu that appears, select "Override Graphics in View."
  2. Then, click on "By Element."
Step 4: Adjust Visibility Settings
  1. A dialog box titled "View Specific Element Graphics" will appear.
  2. In this window, find the option labeled "Visible."
  3. Check the box next to "Visible" to ensure that the section box is displayed.
Step 5: Confirm the Changes
  1. Click "OK" to apply the visibility changes.
  2. Finally, click on "Finish" to exit the "Reveal Hidden Elements" mode.
Now, the section box should be visible in your Revit 2025 view.
Message 39 of 39
thetnwaynyein
Community Visitor
Community Visitor
Thanks @ AlexDT Great Help !
