Section Arrows Missing
I'm sure this is super basic, but I'm just learning so please help:)
Creating a section and when drawn on the floor plan only a straight line appears not the standar bubble arrow on one end and the block marker on the other.
I tried loading a family from the annotation folder, but I can't seem to find the loaded bubble head.  I'd prefeer the section to come with the bubble arrow on top instead of adding it after the fact.
Thanks everyone
RDAOU
Hey @Anonymous
  1. Select the Section line visible
  2. Go to Properties Palette > Edit Type
  3. Click the [...] in the Section Tag
  4. In the following dialog select the Section Head and Section tail you want
  5. Click ok twice to go back tot he model
Excellent video.  Thank you so much!   Figured it out with your help.  Thank you!  Really appreciate the video.
RDAOU
@Anonymous
They are found under Annotations in the Content Library...
1.. Go to Inset tab > Load Family
2.. Navigate to the Annotation Folder int he Content Library of the Revit Version you are using
3.. Load them into the project
I am using Revit 2014 and US Metric ... so they would be located under C:\ProgramData\Autodesk\RVT 2014\Libraries\US Metric\Annotations
