Scope box visibility will NOT turn off
Workshared revit model, 2015, with linked models also. In default 3D view, with view template. Scope box visibility is turned off in the view template, but the scope boxes will NOT turn off! I believe this is a bug, but can't find where to submit bugs for review.
CoreyDaun
If you are certain what you are seeing is not a "Section Box" or some other entity (click on it and it'll be identified under Properties), then use the link below to report it. This link is frequently provided by Autodesk personnel, here.
Autodesk Product Support
The following link is setup for you to submit feature requests, or feedback, directly to our Development group:
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Done, thank you. Definitely a bug.
