Image Rendering Alignment
Hey everyone, hope you can help me in this one!
I'm trying to render an Image as a Material, but no matter what I do, It never gets centered. Is there anything I'm doing wrong?
Attachments below are the .rfa, the image used and the render test
Thanks in advance!
constantin.stroescu
I suggest ,better , tu use Decal:
https://screencast.autodesk.com/main/details/fc7b53c0-f2d2-40e2-9325-3782b87ffbe2
Constantin Stroescu
constantin.stroescu
Though ,I did not recomend ,in this case, to use materials (It's better to use Decal) , and I'd rather apply materials in Project  where the rendering can be done (after as a first step I added a Material Parameter)
Here is an example of material texture mapping screencast:
https://screencast.autodesk.com/Main/Details/1113ce46-8434-43e9-b894-8b78d8f27fe0
Constantin Stroescu
