Schema Conflicts in Revit 2024 - Conflict when linking a model to a site (updated to 2024.1, still not working)
ale_jablonski
ale_jablonski
Hi guys, this is the error:
This is my revit version:
When I choose "continue loading..." it still crashes.
And i have a project to deliver next week 😅.
Any ideas guys, please?
Thanks.
ralphdenhaan
Can you try to Audit the model before opening?
Select Accept as Solution and Likes are always welcome.
Ralph den Haan, (Lazy) BIM Specialist
LinkedIn | LazyBIM Blog
ale_jablonski
Thanks for your reply.
The thing is, after, i found out that sometimes i can't even open 2 different projects at the same time, in that case, opening as Audit helps. But linking a model to a site plan in Audit mode doesn't work either. I wonder if it's caused by enscape materials I used on my model and also on my site plan.
