Hello everyone,
I'm hoping someone can help me crack this one. I would like to have a 2 fields within my materials takeoff schedule to calculate the total amount of studs needed within my project. This is the formula I'd like to use. Total Studs = (Total Length / 1.333') + (5 or 4 * Amount of walls)
Length being : Linear Ft
1.333' being : 16" O.C. in Ft
5 or 4 being : 2 studs, one @ each end + 1 bottom plate + 1 single top plate or 2 for double top plate.
The fields would respectfully be Loadbearing and Non-Loadbearing then I would add those 2 totals to get my total stud count.
I am able to automatically get the numbers I need to do the calculation manually but I would love to automate the entire process.
This is currently where I'm at.
Gelöst! Gehe zur Lösung
Gelöst von Revit_Whisperer. Gehe zur Lösung
@Anonymous
If you have all the values needed, would adding a "calculated parameter" field to the schedule be considered automation?
Or are you looking for some sort of solution like dynamo?
My first idea was to create a calculated parameter however, I couldn't find a way to add the type total within my formula and the total Linear Ft. I consider myself still a bit new to schedules so if that is an option please let me know.
As for dynamo, I have not explored it very much. If you believe that my solutions would most likely be there then I'd rather shift my attention to learning dynamo.
If you wanted to separate the Bearing from Non Bearing you could duplicate the schedules and modify as shown. I always keep one schedule (working) with everything that doesn't go on a sheet.
This looks like it is close to what I am trying to do too. Correct me if I'm wrong: The length field is the length of the wall. Doesn't Revit know about the plates and other framing elements around windows and doors. One more question how can you get a total of these items?
Yes, the length field is the length of the wall. For a Revit wall you construct the layers of the wall, not the construction. Layers being drywall, stud, sheathing etc.
You want a total of all of the walls and their studs...don't itemize by every instance and don't filter and that should give you everything.
This may be a silly question.. Where do you add stud spacing?
Being able to use that in the calculation would be fantastic
In the screen shot shown up a bit in this string, there is a parameter named spacing which I created to determine the stud spacing. It is length parameter.
