Schedule Sum of Columns
I am using Revit 2017 and I have created an electrical circuit schedule. One of the categories (column) is voltage. I was wondering if it is possible to sum all the voltages in the schedule and show it at the bottom of the list. Everything that I have found online shows that I can add, sub, mult. things that are in the same row but I have not found anything that can sum up everything in one category.
Thanks for any help!
PijPiwo
Make sure calculate totals for that field is selected (pic 1) and grand total is checked (pic 2).
Sahay_R
Go to the Formatting tab in Schedule Properties.
Select the field with the desired information in it. Select Calculate Totals.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
kadmonkee
are you talking about a Panel schedule or a custom schedule?
if it is a Panel Schedule you will need to modify the Panel Schedule template
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
