Schedule Report Export Shortcut
BIMAbhi
Advisor Advisor
Message 1 of 13
BIMAbhi
How to create shortcut for Revit Schedule export. We have attached a snap for youre rerefence. We have created the shortcut but not work .Thanks in advance.
Thanks & Regards
BIMAbhi
Replies (12)
Message 2 of 13
LisaDrago
Hello - I see what you are saying, the shortcut does not work.
What I am seeing is that when I try the shortcut - it is trying to fill in one of the fields with what I type.
Not sure you will be able to actually get it working.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 3 of 13
BIMAbhi
Thanks for your response.
Our main intention is to create a short cut command for the marked one portion in the snap. Mainly we can create a shortcut command for schedule export in csv format.
Without using shortcut we have to follow the mentioned steps:
1. Go to the specific schedule which is required to export
2. Then go to Application menu "R" > Export > Reports >Schedule
3. After we can save the schedule in csv format.
Thanks & Regards
BIMAbhi
Message 4 of 13
BIMAbhi
Hello LisaDrago,
We are waiting for your suggestion.
RNDPIS
Thanks & Regards
BIMAbhi
Message 5 of 13
LisaDrago
Hello RNDPIS - at this time I have no other suggestions, other then doing it through the application menu as you have stated.
No one else has responded - so I do no think there is another viable way.
LD
Message 6 of 13
Alfredo_Medina
@ the OP :
If I understand correctly, that tool exports schedules as .txt extension, only. A simple shortcut is not going to save you the step to save the .txt as .csv. You may need to do that in Excel or a text editor, anyway. Probably you don't need a shortcut but a macro.
Message 7 of 13
BIMAbhi
Thanks for the response. Mainly we need to create a shortcut for schedule export in csv format as we press WA shortcut for wall creation (for example).
Thanks in advance!
Thanks & Regards
BIMAbhi
Message 8 of 13
Alfredo_Medina
Not possible as a shortcut. The tool does not even save in that .csv format, so you will need to do some additional clicks in another program anyway. You need something more advanced than a simple shortcut abbreviation.
Message 9 of 13
@Alfredo_Medina Is there any way to export schedule as .txt file using shortcut???
Message 10 of 13
Sahay_R
@Anonymous  - open a schedule.
Then File>>Export>>Reports>>Schedule
You will be able to save it to a Delimited Text (.txt) file
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 11 of 13
lukas.pragt
Quite an old post, but I found this helpfull video..
Message 12 of 13
MachielAEC
Schedules don’t really like shortcuts as it wants you to fill in info into a cell even if a non-editable cell has been selected.
what I can recommend is to rather use DiRootsOne plugin and the Sheetlink feature as this will allow the export of single/ multiple schedules. FYI, its free
https://diroots.com/revit-plugins/dirootsone/
Machiel Odendaal
---BIM Enthusiast---
Message 13 of 13
@BIMAbhi, @lukas.pragt answer is kind of a solution. You should mark it as such!
