Schedule Problems
Schedule Problems
jochia13
Schedule Problems
jochia13
I have created a door schedule in revit. Parameters such as Thickness and Sill Height are not working properly. Specifically, I typed in a value of 2” for Thickness and a value of 2 5/8” for Sill Height and shows 0’ - 0” instead, but when I put the curser in the cell it shows 2” and when I remove the curser it shows 0”. Please tell what am I doing that is causing it to work this way. Do I need to reset the rounding in Project Units?
I suspect a formula is driving the "Thickness",  or some constraint is preventing you from changing it's value.  Post your file.
jochia13
Hi I was able to solve my problem this time. It kept appear as 0”. Only because it was rounding. The value I enter was 2”. It was rounding to the nearest 6”. Therefore, it keep appearing as 0”. I went under the mange tab and changed the units.
You know you can change the units format of individual fields independently from the project units? Go to Format tab of the schedule, select a field and click tge Format units button.
