In the schedule below, I would like to use the FM d column on the right to convert that information to a lumber size. In other words, if the value equals 0' - 5 1/2" it will display as 2x6, or 0' - 3 1/2" would display 2x4. These are AGACAD schedules btw, so maybe there is another easier way that I'm not seeing. I just can't find the fields that might display this information. It seems like there should be a way to write a formula that basically says some thing like If (FM d = 0' 5 1/2", 2x6, If (FM d = 0' 3 1/2", 2x4, 2x8))). We do have some 2x8 walls. Any thoughts on this? I've thought about renaming the families, but would rather not change things like that if possible.
Kevin Mendenhall
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
