Schedule Formula
Schedule Formula
DrakeCanyonArchitecture
Schedule Formula
In the schedule below, I would like to use the FM d column on the right to convert that information to a lumber size. In other words, if the value equals 0' - 5 1/2" it will display as 2x6, or 0' - 3 1/2" would display 2x4. These are AGACAD schedules btw, so maybe there is another easier way that I'm not seeing. I just can't find the fields that might display this information. It seems like there should be a way to write a formula that basically says some thing like If (FM d = 0' 5 1/2", 2x6, If (FM d = 0' 3 1/2", 2x4, 2x8))). We do have some 2x8 walls. Any thoughts on this? I've thought about renaming the families, but would rather not change things like that if possible.
Kevin Mendenhall
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
Use another column that uses a Text Parameter Type with formula = if(FM d = 0' 5 1/2", "2x6", If (FM d = 0' 3 1/2", "2x4", "2x8"))).  Put quotes (e.g. " ") around values.
Awesome, that worked, thank you! Revit made me take one of the parenthesis off at the end, 2 instead of 3.
Kevin Mendenhall
