Schedule Formatting
Schedule Formatting
DJHarrisEA6RG
Schedule Formatting
DJHarrisEA6RG
Is there a way to "left justify" the description header.  Currently it appears to be centered.  Really I'd like the "D" to be somewhere above the "cha", in the word mechanical below.
DJHarrisEA6RG
I see no justification options in the Appearance tab.  I did find an "align text in column" (located in the ribbon) in your "HELP | Format a Schedule" link.  That appears to do what I need.  I had to add spaces to move it to the right, to where I wanted it.  Also, It does not affect the rest of the schedule alignment / justification.  I tested it to see if it affected the "Left, center or right" alignment, in the "formatting" tab.  It did not.
HVAC-Novice
make sure no template is applied
Revit Version: R2026.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
You can highlight column header(s) and align.
Mike.FORM
Once aligned left you can then just add "spaces" before "DSECRIPTION" to get it to where you want.
handjonathan
Hi @DJHarrisEA6RG
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @barthbradley @HVAC-Novice @ToanDN @Mike.FORM helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
