Schedule Footer Formatting
ashdon.mcfallVT2XN
Message 1 of 10
ashdon.mcfallVT2XN
Hi all,
Is there a way to format footers at all? I would like the subtotal shown in the attached to be underneath the occupancy count (Column E) instead of at the bottom of each for Column A
Replies (9)
Message 2 of 10
Format Occupancy to Calculate Totals.
Message 3 of 10
Is Occupancy the in-built Text Parameter?
Message 4 of 10
ashdon.mcfallVT2XN
Sorry i should have described how the schedule is producing its results!
So the 'Occupancy' column is actually 'Count'  - The number of which is calculated from a specific chair family (family field is hidden)
The schedule is filtered by Room (Department column) first, then family (chair)
Message 5 of 10
Message 6 of 10
Format Count field to Calculate Totals and set the footer to show Title and Totals only.
Message 7 of 10
Post your File here via Attachment in Reply Post.
Message 8 of 10
ashdon.mcfallVT2XN
I cant seem to format the count field
Message 9 of 10
ashdon.mcfallVT2XN
This looks promising! Il take a look at this a bit later and let you know how i get on. Thank you for sharing the link!
Message 10 of 10
Add a calculated value of parameter, enter 1 in the formula, format it to calculate totals, and use this parameter in lieu of Count.
