Schedule Fields and Revit Links
PhilvK
Advisor Advisor
PhilvK
I have a field for Original Issue Date in my model and am able to fill that field in on my sheet index schedule. My sheet index schedule is populating correctly with the sheet names of the other discipline's sheets that are part of the project in BIM 360, but their models don't have the same parameter so I can't fill in that field on the schedule.  I don't have time for them to add that parameter, so is there another way to be able get the field to be able to be filled?
- Select the links and change Name to the date you want
- Add a combine parameter
- Hide the original date column
PhilvK
Perfect. Thanks!
