Schedule: custom hide total from footer
XXalessio.amodioXX
XXalessio.amodioXX
As in pic I would like to hide total of length but show total of volume.
Is it possible to customize the footer totals?
Diego.Faria
On your formatting tab, is your DÉLKA parameter set to calculate totals? If it isn't, it should show like this:
Diego Faria
LinkedIn
XXalessio.amodioXX
both parameter are set as "Calculate totals" because I want to see the total lenght per each type.
The Footer is set as "Show only totals", but I want to hide the DELKA (lenght) total in the footer.
Is it possible somehow?
Under 'Sorting and Grouping' check 'Grand Totals' and under formatting you can determine if the totals are calculated for each category - see attached image.
XXalessio.amodioXX
In pic enclose you can see the result I want to achieve.
Diego.Faria
If you select the Calculate Totals option for the Length of your wall, it will always show in the Footer.
Diego Faria
LinkedIn
XXalessio.amodioXX
Exactly what I was afraid of.
