Scales and Text size
Mohamed-Nassar
Mohamed-Nassar
 there are standard for scales and ext size checked before to keep them readable with drawings?
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
Accepted solutions (3)
_Vijay
it will change as per BEP and standard code.
Vijayakumar
Head of BIM
Did you find this post helpful? Feel free to like this post.
hmunsell
Revit scales text based on the scale of the view. You can Google "Drafting Text Scale" for a examples and full lists of the text scale factors used for each drawing scale.
Howard Munsell
emodderman
When you set up a text style, you set the final paper-space size of text you want to see, regardless of the scale of the drawing.
Standard text is typically 3/32" or 2mm and no matter what the scale of your view, your text will be this size when plotted. Saves a lot of work from the traditional CAD workflow, trying to figure out each text size in each drawing scale.
If you plot a large size drawing onto a smaller sheet for something like a half-size checkset, the text *could* be unreadable/too small, but there isn't much you can do about that.
Depends on your local drafting standards and permitting jurisdictions. Ours specifically required the text is not less than 1/10" so our text size in Revit is 7/64.
How far away from the drawing will the reader be?
Mohamed-Nassar
normally with execute from it in the site, but why this question?
