Scale of Callout
Scale of Callout
tstewart
Scale of Callout
tstewart
The Callout scale is too small, so how to change the scale (all scales sizes are greyed out)?
syman2000
Edit the view template and change the scale to 3/4". If this template is used for 1/8" scale, then check off the scale from the view template and you can manually set the scale for each view.
tstewart
Thank you again.
mhiserZFHXS
Or make a new view template at 3/4".
