Scale not Displaying on Viewport
ben
Message 1 of 15
ben
Screencast isn't working, so I'll try my best and use screenshots.
I put a view into a sheet, but the scale for the viewport isn't showing up. The box displays, but the scale isn't showing up in it.
The scale is set to 1/8" = 1'-0"
When I go to the Family Editor for the Viewport and check the Label it looks like everything is correct.
Not sure why it's doing this. Can anyone help?
Also, does anyone know the name of the exe for Screencast so I can try and kill it in the Processes tab of the Task Manager?
Revit lives in the land of perfect and doesn't understand what construction is.
Replies (14)
Message 2 of 15
cbcarch
-Select the Viewport, the go to Properties. See what View Title, and other items are shown/selected.
-Also, try changing the View Port Type to something else and see if the scale appears.
-If so, then it's something with your View Title/Viewport Type named "VIC"
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 15
ben
I've tried changing the viewport type in the type selector to every one of them, including the default Revit one called Viewport1 and it's still the same.
Message 4 of 15
cbcarch
From the Browser, go to Families>Annotations and select/right click> edit the View Title.
Select the Scale Label--check under Properties if Visible is checked.
Cliff B. Collins
Message 5 of 15
ben
Everything looks good.
Message 6 of 15
cbcarch
Hmm........something is not right with your Viewport/View Title setup.
-Try starting a new Project, create a quick Floor Plan, place on a sheet. Any luck?
Check which Template file is selected when creating the new project--it could be something in the template which is causing the problem. Perhaps try <None> under Template file, and then test Architectural template when starting a new project.
-Another thing you could try is to open a "good" project that has the scale in the View Title, and copy/paste and/or Transfer Project Standards into your current project.
Cliff B. Collins
Message 7 of 15
ben
Is it because it's a 3D view on a sheet? Even though the 3D view is locked?
Message 8 of 15
cbcarch
Your question and screenshots did not appear to be a 3D View?
But, yes- a 3D view on a sheet will not display a scale.
Cliff B. Collins
Message 9 of 15
ben
If I make a View Scale on the Title Block is there a way to make that grab the scale size of the Viewport of a 3D view on a sheet?
Message 10 of 15
I am also having the same issue. If anyone has any suggestions, I'm all ears.
Message 11 of 15
ben
Are you using a 2D or 3D view? I found out that they don't display on 3D views
Message 12 of 15
micphillips
View scales cannot be shown in 3D views placed on sheets. To work around this, create a new shared parameter. It can just be a text parameter. Create a new view title type and change the label for the scale to the shared parameter.
Message 13 of 15
g.blanch3TTDT
Community Visitor
Community Visitor
tHANKS
Message 14 of 15
PhoenixChen_XP
https://www.facebook.com/share/p/f31EPry8Z8NLfZZR/
at 6:10
You can see the way to do.
Message 15 of 15
kevinRPT57
Observer
Observer
i edited the label prefix and suffix to put the 1/8" = 1'-0". it's janky but works since everything i do is in 1/8" scale anyways.
